0 members (), 186 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#1117923 08/08/2015 12:37 AM
Hi Everyone, so last weekend I purchased a 1962 GMC numbers matching Pickup truck with a 305 V6 from the original California owner. The motor appears to be lockup so my favorite engine shop is going to remove the engine and rebuild it. The question is what's the best place to purchase engine parts?
Chevytruckdaddy
Napa should have them. If you want to go mail order I have had good luck with RockAuto.com, good luck with your project.
Martin, both places will have replacement parts for this motor? What if it needs bored?
Chevytruckdaddy
Yes. Machine shop for the boring. They will usually supply the parts if you ask or they will tell you what to order.
