7 members (Tim Canfield, WICruiser, 55shaker, Gdads51, Hotrod Lincoln, greenie-reddy, 1 invisible),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,379 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Picked up My 1946 Suburban today. Have some questions, any help is appreciated 1) headliner bows, are there any? Was this fabric or cardboard? , I see a tack strip attached to the roof bows, what where why? 2) I have all the wood window frames , all in good shape , what covers the "walls" of the truck from bottom of windows to roof line? 3) glass channel for the rear side windows, who carries new channel? 4) who besides Jim Carter carries parts for the old Burbs? Thanks for the help
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | #4 the filling station, bow tie bits, steel rubber is the best for rubber parts. #3 do not know anyone who carries the side window channel. the doors should be the same as the trucks. i put power windows in my 36 suburban for about $300.my 36 had metal pieces between the windows and from the windows down to the floor | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | #1. The vinyl headliner attaches to the tack strips. #2. The vinyl headliner comes down to the top of the widows and down to the lower panels between rear doors and rear most windows. There should be the same material on the posts between the windows from the lower panel to top of window. #3. Still looking for window channel myself, but it seems like it is similar to other channels. Also,There are rubber seal strips nailed to the wood framing that supports the window mechanism. #4. Already covered.
Much luck and have fun!
Richard J Patrick - 1946 Suburban
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | | | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Thank you for the info, I appreciate it
