| | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | 1953 1/2 ton with a 261 using a rebuilt foot starter on a 12 volt sys. Normally starts fine but today i stopped at the store and when i came out and tried to start it the foot pedal felt funny like it was not up as high as normal. Luckily i had some tools and started checking things out. I finally took the starter off and I could tell was in a bind and when i put it back on it started right up like normal. It's done this before but it's rare. Any ideas what the problem might be | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | A worn out drive gear, drive gear bushing, and/or starter return spring can cause 'binds.'
You'll just have to disconnect the battery & fiddle with it some so you can observe it happening. Make sure the starter is fully seated & torqued to the bellhousing.
"Not up as high as normal" means it didn't fully retract/return.
Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | What about shims. do these old starter ever need them
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | What about shims. do these old starter ever need them Sometimes. I only have experience having to use a shim on a starter at initial installation; not after it had been on an engine for a while. Shims would come after doing some other investigations- if they were even needed. You said when you removed the starter & put it back on it started right up like normal. You said it (bind) rarely happens. Were the starter bolts tight/torqued when you removed them? Brad Wrench Fetcher, PhD | | |
