6 members (jmoore, 2-Ton, 68ironhead, 55shaker, dt235sd, Joe H), 84 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#1115418 07/24/2015 2:42 AM
How to tell the difference between a 6 volt and 12 volt starter?
scottss60 #1115424 07/24/2015 2:59 AM
If the metal tag is still on the starter, the 6V ones have black paint, and the 12V are red. The 12V has a smaller-diameter armature shaft that the 6V, but I don't have a measurement handy for either one. Both starters have the same number of gear teeth, but the tooth pitch is different, IMHO.
scottss60 #1115539 07/24/2015 11:47 PM
Gas Pumper
Gas Pumper
If you can see the flywheel, check to see if you have 4 teeth per inch (139 tooth SIX VOLT Flywheel), or a 5 teeth per inch 168 tooth (12 Volt) flywheel. You can drop the access pan underneath to verify. The starters are not interchangeable so its a very good idea to know for sure which one you have.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
scottss60 #1115561 07/25/2015 1:50 AM
Yes, counting the teeth on the flywheel will confirm 6v vs 12v.
It is not so easy checking for a 6v vs 12 drive gear on the starter. The number of teeth are the same on 6v and 12v starters. Last summer, I caught a rebuilder (who knew better) using a 12v drive gear on a 6v starter rebuild.
