| | | Forums66 Topics128,164 Posts1,056,965 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | Just bought new drums. Ground off rivet heads to remove old drums. It would sure be convenient to be able to take drums off and on without having to pull the hub assembly each time. GM must have riveted it all together for a reason. Has anybody had a long-term experience with a separated hub/drum set-up? Pros and cons? Thanks!
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
| | | | | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | Most manufacturers figured out that riveting front drums to the hubs was a waste of time and money. As long as the drum is a snug fit onto the hub center, the wheel will hold the drum on tight enough without riveting it. The main concern will be runout, which shouldn't be a problem if there's a good fit on the hub. If you haven't removed the stubs of the rivets, leave them there to act as extra alignment dowels, even if you have to file them a little to allow the drums to slide over them. Jerry
| | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | That's what I thought too. I still have the rivet stubs intact. Thanks Jerry. Dave
