0 members (),
201
10
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 28 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 28 | Hello, I am looking into purchasing a 46 Chevy dump truck. I believe it's a 2 ton. It needs rear cylinders (anyone done this job, is it difficult?). Also wondering what are some unique characteristics to the 46 models. And where will I find the ID badge? Thanks! | | | | | Joined: Jun 2009 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 79 | Welcome to the group, Good luck with the new adventure.
| | | | | Joined: Feb 2012 Posts: 28 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 28 | Thanks, I reposted this in the General Truck forum (with photos) and am interested in attending shows and events in the Denver Metro Area. Also, I will post progress photos as I work on making this truck a reliable work truck - once I own it. -Scott | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | Don't know if you got any response on your question about the rear cylinders or not. I did mine a couple years back when I woke my truck from a 20+ year nap. Pretty straight forward actually. My truck is a 53 2 ton Cab Over. Probably not exactly the same as your 46 but brakes are brakes right? Got some kits at NAPA. Two cylinders on each wheel. I think they're 1 1/2" diameter. Hardest part sometimes is getting the wheels and/or drums off. Big hammer and a piece of firewood helps. Anyway, good luck with it.
Geo | | |
