6 members (Donf, dt235sd, Wally / Montana, Hanks custodian, 32Fordpuchoptop, mason86), 109 guests, and 2 robots.
Topics128,049
Posts1,055,658
#1114947 07/21/2015 3:40 PM
Gas Pumper
Gas Pumper
I added a section on carburetion to the How-To Article here:
http://devestechnet.com/Home/TheVenerable261
Special thanks to Pre68Dave for the new pictures and the knowledge! It's amazing what we can do with our knowledge when we work together! This is great information for you 261 owners out there.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #1115010 07/22/2015 1:54 AM
I likely have run 235 carbs on my 261 without ever knowing this info. So thanks! So did the larger throttle body fit a corresponding larger opening in the intake manifold as far as the mount is concerned?
Drew
Deve #1115013 07/22/2015 2:11 AM
Mounting and manifolds are the same 235-261.
My Blog
Deve #1115080 07/22/2015 2:20 PM
Gas Pumper
Gas Pumper
I didn't want to answer without checking first, but the manifolds we use have a 1.800 inch opening for both 235 and 261 (obviously since they are the same) so no worries on choking the flow with the manifold.
HOWEVER, the plastic carb riser that you get from the vendors is tapered and is 1.715 at the top and 1.690 at the bottom. Since the 235 gasket is 1.685, you are good to go on the 235 but the gasket that has the 4 slots is 1.780. So, my 261's use the 4 slot gasket so I am good there, but wonder if our black carb riser is a choking point on the 261? If so, any recommendations on how to make that hole bigger without ruining it?
Deve
The Think Tank
