7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | I am not sure where to buy zero rust? | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Contact Carl Huether in Pelham NH for product. 800-762-4077 Cheers, Bruce Palmer [email protected] | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Bruce, I received everything and visited the San Jose outlet. Thanks for your help.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | cmayna,
I'm in the San Jose area also. Can you post info on the local outlet?
Thanks, LT | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | LT, Looks like Craig had to toddle off to work or play so I'll answer for him. Try Finishmaster or Center Paint. They both buy from the warehouse in Santa Clara. Another good one if you get into SF is Coast Marine & industrial right down on the waterfront. Any problem finding product just email me at [email protected]. This thread could go on for ever...... Cheers | | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | Bruce, Thanks for the info. You're right that it could be a long thread if all Stovebolters start asking the same question.
Perhaps a dealer's list on your site could answer many of them.
Thanks again LT | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | LT, I thought about the dealer list but the way things are growing across the US & Canada, it would be a full time job just to keep it current.
It seems like in most cases when I do get emails about local sources, there often is a "how to" question included so I can handle those at the same time.
Plus I think most everybody likes to get a response from a person....
Always looking for restoration oriented dealers though if any of you are into shows and swap meets, etc. | | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | | | | | | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | What is "Zero Rust"? Better than POR 15 ? thanks, jim | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Jim, If you (or anyone) would like to call me at 800-725-4960 I'd be happy to pass on what users of both Zero Rust and POR have told me over the last 15 years. Probably too blatant for me to do it here.
Perhaps board users will chime in with their experiences. We do have dealers in Idaho so maybe buying a rattle can to play with would be the easiest way to fill in the blanks.
I can say this: A state (to be un-named but nearby) is using ZR for their bridge maintenance painting on the coast bridges and a major west coast port (also un-named) is using ZR in lieu of the epoxies they had used for years around their port facilities.
Now, before anybody gets their nose out of joint about "crass commercialism", I was just answering a question.... | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Zero Rust dries rockhard and lasts for a very long time on my truck. In fact, where I put it on a couple of years ago still looks new. I put it on my bumperbrackets, for instance, and it is impossible to scratch with your fingernail or even most tools.
It is easy to spray, acts and thins like paint (of all things).
I have never tried POR15 but find no reason to change.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | J. C. Whitney has it in their new catalogs if you ever use them? They are in Chicago, and on-line now too. There are very few if none sales contacts in midwest or east coast area. Think they need better campaign to get product out there and in sites of people. Spend some money, for cryin' out loud, advertise!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Just don't bother trying to ask them anything about the product. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Bruce, So far I'm very happy with ZeroRust. The final finish is a little flat for my taste so I chase each item with a rustoleum semi gloss black.
Oh yeah!!!!
| | | | | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | Thanks guys, Bruce, I'll probably call you in the spring. If it's better than POR it's awful good.My 40' half tonne is about done. Am lookin at a 72' next. And need to paint some boat,motorcycle 'n snowmobile trailers. Can you mix sand etc with it for non-slip surface? Am interested. Thanks. jim | | | | | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | Thanks guys, Bruce, I'll probably call you in the spring. If it's better than POR it's awful good.My 40' half tonne is about done. Am lookin at a 72' next. And need to paint some boat,motorcycle 'n snowmobile trailers. Can you mix sand etc with it for non-slip surface? Am interested. Thanks. jim | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | CMayna, I thought the semi-flat was just about right for the original look. You think the black used was shinier?
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Oh I get it looking at your pictures now. You were trying to match your powder coated parts.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M, I agree that the original was probably more flat just like the zerorust results, but since I did powdercoating I wanted to match it. Since, I will not be powercoating too many other parts of the truck (to watch my expenses) I will probably revert back to the flat black for items such as frame, rearend and so on.
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Jim, As far as performance is concerned, the moisture cure urethanes of which POR is one, work well for their designed purpose. ZR does also. From there on, it's things like price, ease of use, safety, shelf life, UV stability, recoatability, aerosol availability that put smiles on the kissers of the ZR users. It really comes down to personal preference. There are loyal users on both sides and it will always be thus. I see no reason why you could not load up say the last coat of ZR with some sand for the ol' non-skid.
Craig, The gloss can be brought up in 2 ways, going to a slower thinner (if using bulk) and or a heavier film film. Be careful on the film build as it can really slow down cure if applied too thick. But then, the Oleum folks need their wheels of commerce turned too........ | | | | | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | thanks Bruce, The spray can would be great. Will start lookin for it . Hope it smells better than POR. | | | | | Joined: Oct 2003 Posts: 62 Member | | Member Joined: Oct 2003 Posts: 62 | thanks Bruce, The spray can would be great. Will start lookin for it . Hope it smells better than POR. | | |
