0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#1114749 07/20/2015 5:38 PM
1 Offline
When I got this truck, the heat tube that activates the automatic choke was just hanging down near/touching the exhaust manifold - is it supposed to be fastened some way, or does it just have the be in the neighbourhood?
You can see the end in the second photo here between the intake and exhaust manifolds:
https://flic.kr/p/vX93uj
https://flic.kr/p/tidBVS
Also, the dial was turned quite a ways over towards "rich". (Looks like about 60-70°) I'm pretty sure I read somewhere that it should only be moved about 3 notches in either direction when adjusting. Is that true, or is this much of an adjustment pretty normal?
Did 1949 Canadian Chevrolet trucks come with an automatic choke?
1949 Chevrolet trucks did not have an automatic choke as standard or as an option.
Here is a "universal" choke stove assembly.
1 Offline
No, I should have mentioned that the engine is a 59-62 261 out of a Pontiac car. The carb is a Rochester BC off of an unknown 235.
Have to remember to add that every time I post something...
Sorry! <-- I'm Canadian.
1 Offline
Thanks for the link TC! So that part clamps onto the exhaust header then, I assume?
What is the fiberglass rope/wrap for?
Anyone have pictures of the Chevy version on their stovebolt?
1 Offline
Awesome, thanks TC. One more thing on my "make something up" list to get this engine running! smile
At least you have the steering wheel where it belongs and you drive on the CORRECT side of the road.
