5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
Hi All,
I was attempting to remove the draincock from my 216 to check for residue build up before re-installing this [new to me] engine. The draincock sheared off just inside the block; a 3/8" or larger screw extractor will likely fit.
Has anyone else done this particular removal and can provide some tips or advice on the removal?
Any thoughts on spiral tip versus straight tip extractors?
Should I just drill it out with a 7/16's and re-tap with a 1/4" npt?
Many thanks for the help,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Bill,
The spiral tip extractors have worked quite well for me. Make sure you soak the remnants of the drain cock down with PB Blaster or Kroil and let it sit overnight. The spiral type extractor should remove the remaining part of the drain cock with no problem. Hope this helps.
Tim
1970 VW Beetle
Crusing in the Passing Lane
Heating the area w/ a torch and letting cool will defeat the rust and allow easier removal after soaking.
H Online: Content
Spiral tip extractors just expand the remaining piece tight into the hole, particularly a tapered pipe thread. I'd suggest drilling the fitting out just a little, soak with KROIL and do a little heating, then use a straight-flute extractor.
Thanks all.
I just finished removing the hollow threaded portion after a 2-day soak with PB Blaster and a Hanson #5 spiral extractor (Fixit1958). It required some effort, but it was successful.
Ed & Jerry, I didn't see your posts until after I just finished, those are good ideas as well.
Thanks again.
