7 members (SmalltownTRKGuy, baldeagle, moparguy, carbking, walter74, Sjm, Wooley, Sjm),
341
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Diceman what actuates that valve? | | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | The pressure differential on each side of the valve. Completely automatic operation. It must be installed with the pressure hose on the end opposite the spring cavity which is the obtrusion on one side of the valve. Also the heater shut off valve must be between this valve and the heater core. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Good deal Diceman. I like the idea of the coolant circulating through the heater hoses but not through the heater core during the warm/hot months. Course my 49 216 which is still mostly original seems to work fine as is but may not with a slightly hopped up 235 that's being readied.
Dave | | | | | Joined: Feb 2004 Posts: 29,872 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,872 | I seem to remember seeing an H-shaped heater hose connector with a small-diameter crossover tube that bypasses a little coolant back to the return line even with coolant flow to the heater core shut off. This would accomplish some positive flow from under the thermostat housing to the water pump inlet and assuring coolant flow through the block. Jerry
