9 members (WICruiser, Gray_Ghost, Oswald, Hambone, DaveV, TUTS 59, jmoore, Goach2, Phak1),
110
Mod | | | Forums66 Topics128,184 Posts1,057,271 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 14 New Guy | | New Guy Joined: Jul 2013 Posts: 14 | Hello, So just wondering since I've seen pics of 235's with the exhaust end dowel pins removed and bolts in place, I assume the dowel pins aren't threaded in there are they? Also how did you gents get them out? Just with a pair of vice grips or do they have to be drilled?
Thanks for any help! Have a set of Williams headers and a Clifford 4 barrel intake I'm installing and want to be able to bolt down the ends of the manifolds.
1954 Chevy 2 ton stake Full pressure 235 12 volt 4 speed manual
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | The dowels are threaded same as the other manifold bolts but shorter. I used vice grips to turn mine out. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Threaded yes. ViceGrip's..... They should turn out since they are not torqued down like a bolt would be.
dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | If you take your intake and exhaust (torqued properly together with the gasket) to your machine shop, they will mill the surfaces to perfectly straight. Then you don't need to add more bolts. I paid $46 for that here in Kansas. I wouldn't change the configuration. Chevy didn't feel the need. | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I am willing to bet that Chevy felt a definite need to use dowels instead of bolts. With such a long cast iron manifold, there is a lot of heating and shrinking going on, and the dowels may be there to allow for movement without cracking. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I won't buy that one Carl. To many other bolts restricting the movement. My guess is that it was an aid in the assembly. The line worker used the pins as a guide when installing the manifolds. I've really never seen much of a problem with not having the ends bolted down. Now blowing out the gasket at the bottom flange where the cobs come out....that's another story. I'm replacing the exhaust pipe flange gasket about every few months. Oh yeah, our new guy isn't using the stock manifolds, remember? He's installing Williams headers and a Clifford 4 barrel intake, taint connected together. dg
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Good speculation about why there are exhaust manifold studs at the end of Chevrolet Stovebolt engines' heads.
How do these theories explain why the same vintage/era GMC engines (228/248/270 and probably 302) had bolts or threaded-studs/nuts instead of studs?
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | had bolts or threaded-studs/nuts instead of studs? "Threaded-studs/nuts instead of studs" makes no sense. There are bolts they are threaded and head tightens bolt. There are studs they have no head and need nut to tighten. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Explanation: 1. Weren't as many GMC's made as Chevy's so they had more leisure time on that production line. 2. GMC's were made heavier, stronger more durable than the Chevy so more effort went in to making it that way. 3. GMC's cost more that a Chevy so they didn't have to skimp on the cost of a bolt head. It's been the subject of discussion many times of how Chevrolet Motor Division was full of penny pinchers.
dg
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | "threaded-studs/nuts instead of studs"
Oops, I meant "had bolts or threaded studs/nuts instead of dowels".
Thanks for the correction. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I was not trying to correct just thought I was missing something. Jeffrey | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jeffrey,
Corrections and questions are good things. No sense scratching our heads now (or, in the the future, when a new reader/member wonders about the contents of a post). | | |
