3 members (Hotrod Lincoln, Wally / Montana, Southerntruck), 72 guests, and 2 robots.
Topics128,060
Posts1,055,831
I have just installed CPPs power steering kit in my 53 1300. It has a 1975 power steering pump and a 1969 power steering box.
Is it possible that the pump could produce to much pressure for the older box ? Would I be wise to install an in line PRV ?
if it were a newer pump from the late 80 or 90 (with hydraboost) then it may make a difference, but back then most all pumps put out about the same pressure.
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
Yep, the pressure should be close enough. If you had a R & P, you would want to worry about the pressure a little. I went the opposite way. A Corvette R & P pump with a 1975 Saginaw box. Seems fine for the past three years but somewhere in the back of my mind I worry that I might be over working the pump.
Thanks guys. I will rest easier now. Truck steers much better and isnt all over the road as it was with an unknown make of R&P bolted to the frame. Next step is an anti sway bar for the front.
