2 members (BC59, cmayna), 63 guests, and 4 robots.
Topics128,188
Posts1,057,215
Members48,465
Hello fellows,
I recently picked up a panel truck yanked right out of the early 80s. I'm looking to eventually hot rod it up, but for the time being I need to get it running well enough to be my daily driver in town.
The Rochester 1bbl carb needs replacing, and if I'm not mistaken, its the wide bolt pattern (since it's 1950 235).
What carb would you guys recommend? I'm not going to race it or haul a trailer with it, just drive it a few miles a day in a small town.
Thanks in advance! I'm learning as I go.
-Chris
I'm not sure if this link works, but you can see it here:
https://scontent-ord1-1.xx.fbcdn.ne...20e50cc1cb68565f9121b088&oe=56236B6E
Man that's nice!
Cwhuism
I'm sure someone will chime in here w some help but if not post in question inthe engine shop section for better results
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
