6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
For the life of me I can't remember if the sprung side goes towards the pressure plate or flywheel. Please help.
Always put the spring hub toward the pressure plate. The springs will drag the flywheel bolts if you install the disc backwards. Most clutch discs are marked "flywheel side".
thanks that what i did.this kit didnt come marked and i just couldnt be 100 percent sure.
