4 members (Hotrod Lincoln, Bill Hanlon, Wheelie, sron48), 103 guests, and 5 robots.
Topics128,184
Posts1,057,195
Members48,465
#999892 01/17/2014 1:48 PM
if someone cast new improved headlight stands cast in aluminum and beefed up . would there be a market for them.
C MON LETS GO
Ex Hall Monitor
Ex Hall Monitor
You might have better luck getting an answer if you post this in a different forum that gets more traffic. Maybe the Paint and Body Shop forum. Good luck with the project.
cost is a factor, I might.
1938 Gmc 1/2 ton
im due to meet a guy soon with view to getting two cast in aluminum.im expecting good quality material with an improved stronger design and material that could be welded if it was damaged.time will tell.i will post after i meet him
C MON LETS GO
drove 400 m round trip to meet the guy.said he could and would cast up new ones.after then becoming very hard to contact eventually i recieved two new headlight stands.i was hoping for a better finish but i cleaned them up.they are in a friends machine shop to finish the machining.cant post a pic but they are turning out well.they will b painted satin black like the rest of the truck.a lot of work but well worth it in the end.cast in aluminum this time
C MON LETS GO
how do i post pics on this site please.i painted the headlight stands,i would like to show u them
C MON LETS GO
help im looking for a fuel filler neck grommet for my 38 pu.ive 4 different grommets but none fit.where can i get one.thanx chris
C MON LETS GO
Ex Hall Monitor
Ex Hall Monitor
<CLICK>
About a year ago I purchased a set off eBay that are cast with reinforcement in them.this guy has a few made here and there. They look good. I think I paid around $60.00 for the set.
I'm going to use them on my 37. I don't think many will spot the difference .
1937 Chevy 1/2 ton panel
