4 members (Hotrod Lincoln, Simon1954, Otto Skorzeny, klhansen), 37 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#1113506 07/13/2015 8:11 PM
bad memory, can't find good picture
THe stnlss dash pc's for my 49 3100 are going to be painted between the polished areas.
I cannot remember how these are mounted to the dash.
just-a-hacker
'49 3100 before '99
Sir Searchalot
Sir Searchalot
Probably with screws, nuts or bolts. ohwell DADS50 will have 30 pictures of that. smile
I don't have a pic of that area
But I believe the upper and lower trim pieces have studs and you run a washer and nut from the back.
The speaker grill is just sandwiched in between?
DADS50 #1113711 07/14/2015 7:24 PM
thanks,
forgot about the upper and lower trim pc's
The parts catalogs show as one pc
I found the two pcs in my pile///
forgot where they went... now it makes sense
just-a-hacker
'49 3100 before '99
Moderated by  ndkid275, Phak1
