0 members (),
44
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | On a 1946 2 ton with 13' 8" long bed where would you place a 5' x 5' wood burning oven?
On the front of the bed behind the cab or on the middle of the bed? | | | | | Joined: Aug 2001 Posts: 3,587 Moderator | | Moderator Joined: Aug 2001 Posts: 3,587 | Sounds strange to me. I'd say over the rear axle, depending on how much it weighs. Then make a wood rack behind it or in front of it. Also the pizza fixings in some kind of storage space, somewhere. Steps to get on the bed. A ten pound fire extinguiser could also be handy. Bring it to the Home Coming next spring. We can try it out then.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | How hot does the oven get, and where is your fuel tank located? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Sounds strange to me. I'd say over the rear axle, depending on how much it weighs. Then make a wood rack behind it or in front of it. Also the pizza fixings in some kind of storage space, somewhere. Steps to get on the bed. A ten pound fire extinguiser could also be handy. Bring it to the Home Coming next spring. We can try it out then.
Don I have seen a truck with the oven on the front third of the bed and another truck on the middle third of the bed. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | How hot does the oven get, and where is your fuel tank located? Inside of the heat gets very hot though there is 3" air space between the bottom of the oven and the bed. Under the seat. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Thanks for those links my son will love to check them out. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | 32vid, This will be hard for us to answer without a lot more info. It's all about the weight of the entire package...putting a 2000 pound oven up front might be fine if your putting 2000 pounds of firewood on the rear. Is it safe to assume you have the 160" wheel base truck? If so the GVW for that truck should be 15,000 pounds. With a curb weight of about 5,255 pounds. The 4.500 pound front axle is carrying 2,400 pounds and the 12,500 pound rear axle is carrying 2,855 pounds, so the max payload is about 9,700 pounds. So you can distribute the load to add 2000 pounds to the front axle and 7,700 to the rear. So, what does the entire cooking package weigh (oven, coolers, propane tank, food etc.)? Mike B  | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | 32vid, This will be hard for us to answer without a lot more info. It's all about the weight of the entire package...putting a 2000 pound oven up front might be fine if your putting 2000 pounds of firewood on the rear. Is it safe to assume you have the 160" wheel base truck? If so the GVW for that truck should be 15,000 pounds. With a curb weight of about 5,255 pounds. The 4.500 pound front axle is carrying 2,400 pounds and the 12,500 pound rear axle is carrying 2,855 pounds, so the max payload is about 9,700 pounds. So you can distribute the load to add 2000 pounds to the front axle and 7,700 to the rear. So, what does the entire cooking package weigh (oven, coolers, propane tank, food etc.)? Mike B  160 wb, 15,000 gvw. Oven weighs 3,000 lb. There will be 4 underbed storage boxes that are 4' L 18" H 18" D, two on each side, one in front and behind the rear wheels. One box will be filled with fire wood. Another box will hold the generator. No propane. Water pump, on demand water heater, small three compartment sink, a 48" L 30" H 30" D refrig weighs 250 lb. Behind the rear end and between the two rear underbed boxes wll be a 20 gal fresh water tank an a 25 gallon grey water/holding tank. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | If it were me I'd make a little spread sheet and divide it into two sections, weight ahead of and behind the center of the rear axle. Include the weight of the equipment, sinks, pumps, boxes and tanks plus there contents but not the oven. Then see where the 3000 pound oven needs to set to have a little weight transfered to the front axle. Mike B  | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | Hi 32vid, I import and install wood burning pizza ovens. I also import pizza oven burners from Italy that work with natural gas or propane.
I am thinking of doing something similar with my GMC 450 but only for display purposes, the oven would be set on the flat deck without any need for insulating between the oven and flammables.
Will you be installing the oven directly on the flat deck or will you be raising it up somewhat? I normally set the cooking floor at 42 inches off the ground for the easiest access. If you are installing the oven on the deck do you have enough room to allow for this height with a thermal break between the oven and deck?
Bill | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Hi 32vid, I import and install wood burning pizza ovens. I also import pizza oven burners from Italy that work with natural gas or propane.
Bill The oven sits on to metal runners that are 3" tall x 2" wide. So there is a air gap. The oven manufacturer put a angle iron flange at each end of the runners so the oven then will be bolted to the bed. The bed will be covered in steel. Then anchor braces will be run between the cross members so the anchor bolts will have attachment points and then be tried into the metal frame. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You having a shop do the install for you or are you doing it at home? I'm going to be in Ronkonkoma on the 23rd. It would be nice to stop by and take a peek and visit. | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | You could always use a ceramic blanket for insulation as long as it doesn't get wet.
What make of oven is it?
Bill | | | | | Joined: Nov 1995 Posts: 5,712 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,712 | Sorry to be late to the discussion, but ... Here's a guy in the Gallery who already figured this out You may want to contact him.  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | You having a shop do the install for you or are you doing it at home? I'm going to be in Ronkonkoma on the 23rd. It would be nice to stop by and take a peek and visit. We want to at least farm out the covering of the deck so the job will get done with larger pieces then we can handle. Love to show off the truck but do not know at this point where the truck will be or what stage the conversion will be in.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I have seen that one. And Ed Hotaling gave additional links and I really like one of them a lot.
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I was looking for the one John found for you. It's a really nice setup.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I was looking for the one John found for you. It's a really nice setup. I am in no way belittling John's efforts. I just found that one only a few days ago. And I was not looking for it I just stumbled on it. So I still appreciated whenever people make the effort to pass things on. Jeffrey | | | | | Joined: Nov 1995 Posts: 5,712 Bond Villain | | Bond Villain Joined: Nov 1995 Posts: 5,712 | Jeffrey -- We just want some pizza
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Jeffrey -- We just want some pizza  Maybe some day you will have the best pizza. Jeffrey | | | | | Joined: Nov 2010 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 122 | Check out these guys nomadpizzaco.com it's on a 48 Reo, friend of mine did all the fabrication (minus the oven) | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Check out these guys nomadpizzaco.com it's on a 48 Reo, friend of mine did all the fabrication (minus the oven) Thank you, more great research information. Jeffrey | | |
