0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have a friend with a 56 gmc with the Pontiac 317 engine and auto transmission. I know nothing on these. Does anyone have this setup? Thanks
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | No one out here in the west knows about this combination after the fire?
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No one out here in the west knows about this combination after the fire? Are you referring to the Hydra-Matic plant fire in 1953? (if you are referring to another fire, I'll delete this post - sorry). If you are referring to the H-M Plant fire: "By the time the 1954 models debuted in late 1953, Hydramatic production had returned to normal levels and all '54 model Cadillacs, Oldsmobiles and Pontiacs with automatic transmissions were once again equipped with Hydramatics." https://history.gmheritagecenter.com/wiki/index.php/Biggest_Industrial_Fire_in_History | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Sorry, I know little about gmc's. I heard there was a fire and that's why gmc used the Pontiac engine. Again, sorry.
I am trying to help out a good young man with verbal and moral support for his project. This 56 gmc was his grandfathers. It's in pieces and he has the will to get it back together. It has the Pontiac 316/317 engine and automatic transmission. I believe he has the original setup. He said he cannot find engine mounts.
How hard of a project has he gotten into? I told him to get the manuals and find web sites.
Thank you
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dennis,
You do not have to apologize. I was just posting information.
Are the transmission and engine together/attached?
You might want to suggest that he find a shop that works on automatics/hydra-matics - a shop that would know about the mounts (a H-M rebuilder might not know that information).
Maybe someone will post the name of a shop in SoCal that knows old H-Ms and engines? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You might try Turners just south of Fresno. It's almost worth the trip just to look around but they ship out too.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd suggest he study the info at oldGMCtrucks.com and join the discussion forums there. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I know nothing about the 317 GMC engine but when I googled it it sure looks like a Buick Nail Head instead of a Pontiac. The exception is if it has the Tri-power set up is a Pontiac engine.
Evan
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It looks nothing like a nail head Buick except for the fact they are both V8 engine. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | GMC trucks used Pontiac V-8 engines from 55 through 59. 55-287, 56-316, 57-347, 58&59-336. They also used the GM Hydramatic trans. Some of the larger trucks used Olds engines.
Dennis, I'll ask around. One of my friends had a Hydramatic trans done for his 57 Cameo a few years ago. It still works so I guess the shop must be OK. Fred
