3 members (Jay R, Hanks custodian, 1 invisible),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | On the 49 AD 1/2 ton, there are six bolts that (by all the drawings I've seen) go through the bed wood, cross sills and frame. Is there any reason why I can't install the bolts first and put the wood over top of them by making a recess in the under side of the bed wood to clear the bolt heads? This would look better and I can't see how it could substantially weaken anything. Am I missing something? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | A buddy of mine did the exact thing on his 46 without any problems. I'd say go for it. George | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The bed sides don't have much lateral support without the bed wood bolted down. I would install the bolts the normal way, or mill a keyhole (or T) slot with a router table in the bottom of the wood so the bolts could be hidden.
