3 members (78buckshot, baldeagle, Rusty Rod), 109 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#1112031 07/06/2015 1:27 AM
Just inherited a 55 3100, frame off restoration complete, very good shape, engine runs great but needs cleaning up, grease, crusty. Suggestions ?
55 3100 standard cab
Take it to the car wash. Plastic bag taped over the carb and distributor. Good hot soapy water and get after it. Take some old towels to dry things off and a can of WD40 to spray the inside of the dist cap and points if it doesn't start back up. Driving it there to get the engine good and warm will help too. I'm sure others will chime in with their suggestions.
I was looking for methods the other day.
There's a high view count YouTube video where a guy swears that brakekleen does a fantastic job. Cant verify that myself, but I intend to do a small-scale test on some parts or a lawnmower or something.
1951 3100
Moderator, Electrical Bay
Gunk used to make a degreaser you sprayed on a warm engine and rinsed it off after a few minutes. It worked well unless you had thick or caked on grease.
Jon
~ Jon
Quote
Careful what you use. Brakekleen will eat the paint off anything it gets on. Use a chemical designed for engine cleaning. Your parts house and Walmart will have several selections.
Harold
Harold
Use a pump-type garden sprayer and a STRONG solution of Trisodium Phosphate (concrete cleaner) Soak things down under the hood, let it sit for a few minutes and hit it with a high-pressure nozzle on a hose. Repeat as necessary.
Thanks to all that replied. chevytrucks.org recommends dishwasher detergent solution applied liberally and then use power washer, of course protecting electrical parts. I'll also look at commercial "gunk" which is pretty effective but only on hot parts. Will leave feedback on how Im make out. Thank you.
Check to make sure that you don't have vents in the valve cover.
Just my curiosity but how did a frame off restore engine get all gunked up.
Stick with the common store engine cleaners, some good biodegradable ones out there that will cut grease and grime but leave paint alone.
Watch out on a pressure washer as they can damage gaskets if to high a pressure, (specifically cover gaskets)
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Thanks for the reply. Good question, I purchased the truck as-is. Don't know why they didn't at least thoroughly clean/paint the engine when the frame was being done. I'm holding off the engine re-build for now, just wanted to clean it up.
