4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#111211 10/31/2004 2:16 PM
My "new" 64 was Ivory. My jobber cannot find a mix for it, he sells PPG & Omni. It is also used as the roof color 64-66. Code is 526, PPG/Ditler #8290 Off-white or Ivory. Does anyone know of or have used a close match? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#111212 10/31/2004 4:03 PM
64fleetside,
I do not have paint chips for your year (to confirm your numbers) but if your numbers (and names) are corect, PPG has an excellent color library that most PPG jobbers do not know about (or, maybe they do not want to make the calls). The color library can tell you if the original color is still available or, if it is not, they will usually have an "offset" number for a matching color.
Here are some phone numbers. If they are wrong (no longer working) please post that information here.
440-572-6100 PPG Color Library - had all codes
440-572-6111 PPG Tech Services Refinish (gave me the number for the Color Library)
440-572-6871 FAX number for the PPG Color Library
Good luck,
Tim
#111213 10/31/2004 4:29 PM
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#111214 10/31/2004 6:51 PM
Thanks, my jobber & I shall try again Monday, will post w/results. Brian
