0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | My "new" 64 was Ivory. My jobber cannot find a mix for it, he sells PPG & Omni. It is also used as the roof color 64-66. Code is 526, PPG/Ditler #8290 Off-white or Ivory. Does anyone know of or have used a close match? Brian | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 64fleetside,
I do not have paint chips for your year (to confirm your numbers) but if your numbers (and names) are corect, PPG has an excellent color library that most PPG jobbers do not know about (or, maybe they do not want to make the calls). The color library can tell you if the original color is still available or, if it is not, they will usually have an "offset" number for a matching color.
Here are some phone numbers. If they are wrong (no longer working) please post that information here.
440-572-6100 PPG Color Library - had all codes 440-572-6111 PPG Tech Services Refinish (gave me the number for the Color Library)
440-572-6871 FAX number for the PPG Color Library
Good luck, Tim | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 |
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Thanks, my jobber & I shall try again Monday, will post w/results. Brian | | |
