| | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Hello, I am in the process of rebuilding a SM420 and have a question on the counter shaft assembly. I believe this transmission was manufactured in 1949. My question is on the spacer between the reverse and counter driven gear (I believe this is correct - it is the only spacer in the counter shaft assembly). The spacer sleeve has only about 0.004" of play in the axial direction when measured with a feeler gauge. There is some movement in the radial direction and when I spin the countershaft assembly I can hear the spacer sleeve making noise as the shaft rotates. Is this normal for the spacer shaft to have about 0.004" play in the axial direction and clank when the counter shaft is turned. I assume that was the tightest snap ring they could get in. The four pins are pressed in but may have some wear. I do not want to disassemble this again if this movement in the spacer sleeve is normal. http://i1285.photobucket.com/albums/a584/1866yellowboy/20150701_175841_zpspm66e6lc.jpgAs always any and all help is appreciated. | | |
