0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | I have a buddy who has the setup for powdercoating, will it handle the heat if i have him do my headers for me? If not has anyone have any suggestions on what to coat them with,been down the spray bomb high temp paint route in the past. You have to take pics before you fire the motor up as it instantly burns off as i am sure most of you know........Thanks, Dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
| | | | | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Hi Dale, I do not know the answer. You might want to check with a local speed shop. They should know. good Luck Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Check these guys out: Header Coatings There may be someone closer to you that does "spray welding". My aluminum coated headers on my SBC have lasted 18 years so far and I expect to get another year or two out of them.
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | headers would get to hot for powdercoating. see if you can find someone that does ceramic coating, and have them coated inside and out.
2003 ford lightning 1959 chevy 36
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | My new Eastwood catalog shows a high temp powder coat 1000* but I dont know if it would work on headers. Probably not. MAy work on down stream exhaust parts. | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Thanks guys, I think I will try the Eastwood stuff. Sorry to say that it will probably another year before i actually fire this puppy up and I will not be able to let everyone know how it holds up till then.........Thanks again, Dale
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Dale The only coating that will hold up long term is the ceramic coating mentioned above. Hold on to your wallet as it us muy dinero $$$
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
