3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#111064 11/19/2004 11:05 PM
I have a buddy who has the setup for powdercoating, will it handle the heat if i have him do my headers for me? If not has anyone have any suggestions on what to coat them with,been down the spray bomb high temp paint route in the past. You have to take pics before you fire the motor up as it instantly burns off as i am sure most of you know........Thanks, Dale
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
#111065 11/20/2004 11:49 AM
Junior Member
Junior Member
Hi Dale,
I do not know the answer. You might want to check with a local speed shop. They should know. good Luck
Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#111066 11/20/2004 5:34 PM
Check these guys out:
Header Coatings
There may be someone closer to you that does "spray welding". My aluminum coated headers on my SBC have lasted 18 years so far and I expect to get another year or two out of them.
Gord
1954 1/2 ton 235 4 speed
#111067 11/22/2004 5:04 PM
1 Offline
headers would get to hot for powdercoating. see if you can find someone that does ceramic coating, and have them coated inside and out.
2003 ford lightning
1959 chevy 36
#111068 11/23/2004 6:49 PM
My new Eastwood catalog shows a high temp powder coat 1000* but I dont know if it would work on headers. Probably not. MAy work on down stream exhaust parts.
#111069 11/23/2004 8:51 PM
Thanks guys, I think I will try the Eastwood stuff. Sorry to say that it will probably another year before i actually fire this puppy up and I will not be able to let everyone know how it holds up till then.........Thanks again, Dale
1939 GMC
1953 HD PANHEAD
#111070 11/23/2004 10:59 PM
Dale The only coating that will hold up long term is the ceramic coating mentioned above. Hold on to your wallet as it us muy dinero $$$
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
