| | | Forums66 Topics128,059 Posts1,055,823 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Installed a new fuel sending unit about 2 months ago, tested it before I install it with the gauge, everything work.Last month I put gas in the tank and the gauge moved, but I had a leak in the pipe from tank to line so drained the tank and fixed it. Sunday I put about 3 gals of gas in and the gauge moved, no leaks so today I put in 5 more gal. of gas, should have about 1/2 tank of gas. But the gauge just move as if it only had the 3 gal. in it. Rocked the truck, beat on the tank but still the same. I don't want to pull the seat to remove the sending unit. HELP 53 3100 root | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | When you are stopping and going while driving, does the needle move back and forth? It should. If it doesn't, the float may be contacting the side of the tank. Been there, done that. Carl
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | should only have to remove the seat back
3 screws | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Yes, DADS50 that is what I was talking about, not the hole seat base. Pulled the seat back, removed the sending unit, bent it a little, then checked it with ohm meter all is good . Reinstall the sending unit turned on key and now I have about 1/2 tank of gas just where it should be. Thanks again DADS50. root | | |
