6 members (GDW, Gdads51, Shade Baby, Shaffer's1950, 3B, 1 invisible), 143 guests, and 3 robots.
Topics128,139
Posts1,056,459
Members48,441
#1110275 06/26/2015 1:17 PM
My machine shop has just informed me that my block has to be cut to 60 over to remove all old ware and taper. Should I be concerned driving a 60 over block daily...will it cool ok...any other concerns ..
ODSS President
ODSS President
My '56 is '30 over', ~95k miles, daily driver, only vehicle. I'd go with the water pump relocation plate and call her 'done'. No other concerns.
~ Cosmo
1949 Chevy Half Ton
You could have them re-sleeve the cylinder to the original bore.
Or go with an increase in displacement and let them bore it. I do not know what the maximum oversize bore is for your engine. You should find that out before you do anything.
Also does your engine have cast iron pistons?
Think about seeing if they have new aluminum replacement pistons. Less reciprocating mass.
.060" is no problem,.080" is even okay in most cases.
My Blog
There are quite a few 216's running 235 pistons- - - -a .0625" overbore, with no issues. Engines bored .080" oversize or larger tend to have short piston ring life and/or overheating problems, but 60 over is no problem. There's a LOT of cast iron in a stovebolt cylinder wall!
Gas Pumper
Gas Pumper
No concerns whatsoever. The water pump adapter is a good idea, other than that, they run exactly the same. Pistons are larger diameter, thus so are the rings, but tolerances between it all is the same, so no worries. Once you get over .080, it's either time to start thinking sleeves or a replacement block. The replacement pistons are aluminum.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
