5 members (Phak1, Gdads51, TUTS 59, DaveV, 3B), 83 guests, and 2 robots.
Topics128,056
Posts1,055,789
#1110229 06/26/2015 3:07 AM
Installed a new fuel sending unit about 2 months ago, tested it before I install it with the gauge, everything work.Last month I put gas in the tank and the gauge moved, but I had a leak in the pipe from tank to line so drained the tank and fixed it. Sunday I put about 3 gals of gas in and the gauge moved, no leaks so today I put in 5 more gal. of gas, should have about 1/2 tank of gas. But the gauge just move as if it only had the 3 gal. in it. Rocked the truck, beat on the tank but still the same. I don't want to pull the seat to remove the sending unit. HELP 53 3100 root
root #1110387 06/27/2015 4:20 AM
When you are stopping and going while driving, does the needle move back and forth? It should. If it doesn't, the float may be contacting the side of the tank. Been there, done that.
Carl
root #1110394 06/27/2015 5:37 AM
should only have to remove the seat back
3 screws
root #1110474 06/27/2015 10:49 PM
Yes, DADS50 that is what I was talking about, not the hole seat base. Pulled the seat back, removed the sending unit, bent it a little, then checked it with ohm meter all is good . Reinstall the sending unit turned on key and now I have about 1/2 tank of gas just where it should be. Thanks again DADS50. root
