1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Background: I have a '54 3600 with the original 235 engine. Just recently got the truck up and running (thanks to these forums  ) and am enjoying it.  I do have lots of things I'd like to do the truck over time and will need lots of help as I am a newb. I am thinking of updating to a 12V system and am curious what y'all think? What are advantages/disadvantages of a 12V system. Also 12V generator or alternator? Finally, I believe the truck is still a 6V system, but am not sure how to tell.
Today is the best day of my life!!!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The only reason to go 12V is for power seats, windows, mega-watt stereo, etc. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Is there now a 6v or a 12v battery in the truck?
I see no advantage to converting to a 12v system. You can still buy 6v batteries, bulbs, radios, heaters, wipers, gauges.
Yes 6v does not charge much at idle. Though you do not need to idle and should not idle for prolonged times. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | For once We agree Charlie! Good 6v battery, good charging system, good solid clean connections and proper grounding, keep the engine tuned and you'll have no trouble with starting, running or lights. If you have a need for 12v supply, such as a tach or moderate output AM/FM stereo, then a 6v to 12v voltage booster is simple to install and relatively inexpensive. http://www.pbase.com/dennygraham/image/139692811dg
Denny G Sandwich, IL
| | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Pretty sure it is a 12V battery. Looks like from Walmart.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How many cells/fillers in the battery (if it has fillers)?
Does the battery have a part number?
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | 12 vs 6 question thoughts.
While at time the 30, 40, and early 50's cars and truck were produced the 6V system was perfectly adequate. And in talking add on loads even then the 6v systems are able to provide. I do remember working around my Grandads garage as a young kid, and seen a mocked up 6V winch on a truck. Of course at the time it looked to me the cable to the second parallel battery and then to the winch looked as big around as my wrist. 6v systems can power anything with large enough wiring, adequate generator size and enough battery current. On the other hand the military found the voltage pressure of 24 volt made for more power with smaller wiring and more punch in starting in the harsh conditions.
But the key to manufacture change is wire size and loads. With the primary area of concern in late 50's lighting and safety. Candle power needed to increase for better night driving at increasing speeds and better lighting for rear to approaching cars. While one could increase wire size and current. MFR went to 12 to provide the boost.
A simple view is if your restoring a show truck or weekend only driver without plans to make freeway trip or heavy city driving leaving the period adequate 6 volt system is the best one can do. But if your creating a daily driver that will see freeway or fast hiway, bright city night driving or even unknown farm roads. A choosing to provide the 12v allowing increase lighting ability should be a choice examined for benefits vs cost of change.
IF the battery has the 6 cap holes of the 12v. I would also look for part numbers on your regulator and your generator and coil to check for 12v versions versus 6v.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks for all the great info. Battery is a 12V. Says it right on top after wiping it off. For now, it is used a daily driver for my 3/4 mile commute and general around town. Truck tops out at about 50mph so no freeway or long trips. Eventually, I would like to have gears changed (?) so I could take it on the highway.
As for long term plans, still trying to figure that out... So many different directions one can go with these great trucks.
