| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 9 New Guy | | New Guy Joined: Dec 2014 Posts: 9 | I replaced the old Carter with a 32/36 from Langdon and it works fine as long as it gets fuel. My problem is that efter running for a while and then stopping the fuel line empties out and it gets hard to start. I have an inline fuel filter (as recommended) an a one way valve after the fuel pump. To solve it for now i put a manual primer pump (think outboard motor..) just before the carb and when i prime it, there is no problem starting. To much heat, vapor lock??? The filter is sitting far away from the engine and it doesn't get hot. Help! | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Bad check valve in fuel pump. | | |
