7 members (Wrenchman, Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, 1 invisible), 52 guests, and 2 robots.
Topics128,089
Posts1,056,009
Members48,430
#1109675 06/23/2015 7:29 AM
I replaced the old Carter with a 32/36 from Langdon and it works fine as long as it gets fuel. My problem is that efter running for a while and then stopping the fuel line empties out and it gets hard to start.
I have an inline fuel filter (as recommended) an a one way valve after the fuel pump. To solve it for now i put a manual primer pump (think outboard motor..) just before the carb and when i prime it, there is no problem starting.
To much heat, vapor lock???
The filter is sitting far away from the engine and it doesn't get hot.
Help!
Bad check valve in fuel pump.
