11 members (FAST55, panel fan, Wayne67vert, Gdads51, Lightholder's Dad, gswbbc, 48jim1ton, frogfarmer, tclederman, Ponchogl, 1 invisible),
106
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | One of the things added to my 'to do' list is to replace the clutch in my '47 AD. Does anyone know how long it took a garage to perform this task in the old days? What would be a ballpark time for a non-professional mechanic but someone with good mechanical skill and proper equipment? Thanks
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Flat rate to R&R Clutch is 3 hours for that type of drive line.
dg
Denny G Sandwich, IL
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Oh yeah, flat rate. If you do this about 6 times you will get close. I remember the Rep from Honda(I did work for them back in the day) came with some training film. We were doing a twin cylinder 250 at the time. Tech on the film set both pistons and rings into the cylinder in less than 10 seconds. Best I could ever do it was 10 minutes. And I was the fastest in the shop. Plan on double the flat rate. Take the time to be safe and smart. Three speed has linkage, and the torque tube. But it can be pulled by hand from under the truck. Not too heavy to manhandle alone. 4 speed, is HEAVY. I won't pull one without a transmission jack or an engine lift. Still have the Torque tube. The clutch and presser(pressure) plate come out and down. Gravity is at work here. The room between the cross member and the bell housing can get tight watch for finger pinch as it comes down. If the flywheel is good(not often) reassemble and all is good. If the flywheel needs to be resurfaced, it is heavy and likes to eat fingers when it comes off the dowel pins. Be safe, be smart, and take the time you need. It is not hard. You can do it. And you will feel good when you are done.
Steve H
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | His question was: "someone with good mechanical skill and proper equipment?"
That's the flat rate taken from a Motors Flat Rate Manual from 1954. I worked the parts counters at Chevrolet dealerships in the late 50's early 60's and the mechanics weren't starving. Most could beat the book rate on the vast majority of their jobs. With the truck up on a lift it shouldn't take all that long to drop the trans, R&R the pressure plate, disk and brg. and shove the trans back in place.
Of course if you're trying to do it yourself in your garage with a floor jack it could take you all day. Heck, you might spend three hours just trying to get the shift lever out if it's an SM420! dg
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I would count on a full days work if you haven't ever done it before. | | |
