2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#1108253 06/14/2015 9:43 PM
I have a 1945 1 1/2 ton with the 235 in it. The engine was recently rebuilt and the truck is running again after a long slumber. We have noticed that the upper radiator hose is hot but the lower radiator hose is much cooler. The heater hoses are very hot. Is this the sign of a bad thermostat? There isn't a temperature gauge so I don't know the temperature of the water in the engine.
H Online: Content
The lower hose is supposed to be cool- - - -that's what a radiator is for. Install a temp gauge and quit guessing.
The top radiator hose is hot water coming from the engine, it flows through the radiator which dissipates the engine heat to the air, the water coming from the radiator is cooler and goes back into the engine.
A bad thermostat needs a water temp gauge to verify.
Heater hose can be very hot if there is full flow in them.
Would suggest a temp gauge be installed, if you do not want one in the dash then mount one in the engine compartment.
Or if none is wanted at all at least buy a HF handheld IR temp sensor, it can not measure direct water temperature but will measure approximate temps on the thermostat housing
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Normal. get a gauge or a temp gun to record surface temp. The rad top to bottom should be 20 degree diff.Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
