0 members (),
78
12
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hello, I was told by a machine shop that you cannot line bore a 6 cyl block; Is that true? and if not why? Thanks | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Most shops don't want to do the extra setup on a stovebolt block, since there are 4 different main bearing diameters. I'd recommend finding a shop that has more skillful (or less lazy) people. I've line-bored plenty of old Chevy blocks, and it does take some special procedures. It's vital that very little material be removed from the block side of the parting line since setting the crankshaft deeper into the block will cause the timing gear teeth to bottom out. I would usually set up the boring tool to remove only .002" from the block, and .008" from the main bearing caps. Jerry
