5 members (carbking, TexasJim50, baldeagle, Hotrod Lincoln, 1 invisible), 91 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#110765 02/04/2002 11:24 PM
Y'all
I sanded the bondo the po put on my truck today and there are holes the size of ball point pen tip in bondo. Can I fill these with something or will I have to grind all the old bondo out and start over?
Judd Pease
sjmodels.railfan.net
#110766 02/04/2002 11:39 PM
Judd,
Under the bondo is there a hole or did they fill in a dent?? If it were me I dont care for alot of bondo.If it is a dent,get rid of all the bondo and fix the dent and then use a fine layer to smooth, if it is a hole definately get the bondo out and repair by welding a patch panel in the hole.Bondo doesnt protect metal from rust and instead of having problems later on fix it right this time.Plus I always take a magnet to a car to see how much plastic someone has added to fool someone else. Just my opinion. hope it helps your decision.
Alan smile
Live every day to the fullest for tommorrow never comes!!!
#110767 02/05/2002 12:25 AM
I think what he means is there were some airholes that he uncovered while sanding. Get a polyester puddy and go over the whole area and sand that smooth. It is meant to fill in the final irregularities left by bondo/filler.
54 3100 with 235
62 flatbed dump C60 with 261
#110768 02/05/2002 1:17 AM
Alan & TonyM
Thanks. I think I'll try the polyester for now as I'm just trying to get this thing close to one color ( white ) for now. It will need a "LOT" of work that I don't want to do now before it is good enough to put a real paint job on. LOL
Judd Pease
http://sjmodels.railfan.net
#110769 02/06/2002 3:26 AM
Hey where can I get some polyester putty at.
#110770 02/06/2002 4:01 AM
I looked in the yellow pages and found a body shop supply place. Find one the pros go to. They have everything you need. It is basically a finer puddy for final surfacing.
54 3100 with 235
#110771 02/06/2002 6:43 AM
When working with bondo...i would sand the bondo down with a disc sander and then block sand it with 80 grit. There would always be valleys or low spots or air bubbles leaving pits etc.
I would just go over it with a thin layer of bondo and sand... and repeat the process until i got all the pits valleys or out. Then still using a rubber block i would wet sanded it with 300 grit until smooth.
Then feather out the sanding marks of on the original paint in the area worked upon and hit it with a couple coats of primer which would fill in those tiny pin holes. Then painted it.
Primer and paint were all from spray can but i had that bondo so smooth that it that it worked out fine.
Starrider
#110772 02/11/2002 5:12 PM
This might be a little late, but a good product to use for filling pin holes is called "Icing" available at most paint jobbers. It's a 2 part polyester putty that fills pin holes, and is also used as a final skim coat over a filler repair. It's about the consistancy of halfway between bondo, and primer/surfacer. And is very easy to sand, unlike a lot of other polyester putties. A lot of the time this is all I use prior to a primer/surfacer as I'd rather fix the dent, and use a bare minimum of filler.
#110773 02/12/2002 2:18 AM
Yea, where ever you buy bondo they usually have
a spot puddy there, auto parts stores sell bondo
spot puddy, comes in a 6 or 8 oz tube ,
jbennett
40 burb
#110774 02/12/2002 2:48 AM
jbennett, the "spot putty" in tubes is really very think lacquer primer and junk. What everyone has been refering to is POLYESTER putty. It uses a hardener and cures like regular "bondo". IT has a finer ground talc so it spreads and sands much easier.
I am going to start a new thread on this subject but will post it here too.
This is a "canned answer" I made up and keep in "my documents" for these occasions. You may find it useful. I have had a number of guys tell me that they printed it out, studied it and now are doing "bondo" work like a pro. Hope it can be of use to you.
What ever tools you use the trick is to not ad the last "skim coat' till you KNOW that it is all you need. Don't try to block out that first coat, just use it as a base for the LAST skim coat.
I was taught this procedure after doing bodywork for a number of years and it really works well:
Just apply a nice coat of filler (what ever brand, whatever style, we will put that aside right now). Cut that coat NOT to make it perfect, but to get the basic shape and filling you need as a base for the skim coat. You can cut it with 36 40 or 80 depending on how big the area you are working is. In other words, if you can cut it fast with only 80 then do it. But I would say that this would be limited to an application that is no larger than about 8 inches.
If you happen to have a few high spots, see if you can tap them down.
If you have a few low spots add a bit more filler to ONLY those spots.
Re-cut these last low spots you have just filled with the same grit you have been using (most likely 36).
If you now have a surface that ONE skim coat will fill, then apply it. If you don't work with it a bit more, but NEVER add a little here or there and think you will finish it without a skim coat.
If you have a surface that is very close with only a few VERY MINOR low spots like poor feathering onto the metal, poor transitions from one application of filler to another, or from the metal that is "poking" up here and there you can do the LAST skim coat.
This skim coat is very important, you want it to extend over the COMPLETE area, this is well past the damage you have been working. Maybe as much as 3 inches past the plastic that you have applied to "rough" it out.
This skim coat can be regular filler or a polyester glaze like "Icing" or "Polyester glazing putty", that is your choice, I use both depending on the size of the area being worked.
You now run a block, long board, or hog even over this skim coat with a little bit coarser paper than you plan on finishing with to cut off the resin that has surfaced in the filler. I usually just use the 36 or 40 or whatever I have been on the "rough" work. BUT take CAUTION not to cut much off, you want to JUST take the very top, don't really sand AT ALL.
Now finish sanding with your longboard or block or hog or whatever using the finer paper like 80 on a large area or 120 on that small 8" sized area. Block it out to perfection with a nice feather edge to the surrounding metal.
I can't stress enough, the trick is to know when just ONE LAST skim coat will do the job. And apply it COMPLETELY over the surface. If you only one little low spot in the middle, DON'T just do it, skim the ENTIRE thing. You HAVE to have one LAST skim coat over the ENTIRE thing every time. If you get in the habit of this you will do it over and over on every dent you repair and find that you can do just about any dent with just
two applications.
Don't worry if you cut through this skim coat here and there. In fact, you WILL most likely cut through. The point of that "LAST SKIM COAT" is that after you add it, you don't add ANY MORE filler. That "LAST SKIM COAT" is just that the LAST filler you add. If you hit a little filler below, or metal, that is normal and fine. The only thing you are looking for at that point is if the panel is FLAT. The filler skim coat is serving no other purpose than to finish you filler work, it is not a "sealer" or anything like that.
You can add fiberglass resin (“A” coat if you have a choice) adding the resin was exactly how I learned from the great Emery Robinson (my personal hero in the auto body world). But remember, there was no products like polyester putties back then. When you add resin, that resin comes to the top of the film of filler. It is then something you have to deal with. The whole purpose of the SKIM COAT is to put a layer of filler over the top that is easy to block out with as little effort as possible. You want to be able to concentrate on making the panel FLAT not fighting with gummy resin, sand scratches and the like.
So the polyester putty though expensive is what I use.
How is this for an idea, a co-worker of mine showed me this very obvious tip. smile
Add pour-able polyester putty to the regular filler! What an idea! LOL A little pour-able squirted into the "bondo" really thins it out nicely.
The "LAST SKIM COAT" should be left to cure a good long time. Where you may jump on filler and sand it as soon as it is hard, the skim coat should be GOOD AND CURED for an hour or more. If you can of course, in the production shop you may not be able to wait that long. The benefits of the procedure will not be diminished.
A little added note, I have found that I don't use 36 or 40 grit at all anymore. I went to work at a shop that didn't use the coarser grits so I had to learn not to also. I have found that using just the 80 and then finishing the Skim coat in 120 or 180 works great, even on large panels.
At this shop it was the first time that I wasn't doing my own primer work. This meant that I couldn't “cheat” with a lot of primer and blocking the body work “one more time”. I found that I had to get the work PERFECT, then give it to the painter. I did this in an interesting way, I look at the last skim coat as even a more “final” step. I now look it as “primer”. You see I have used polyester primer, which is like spraying “bondo”. They are both polyester resin based and act and sand very much the same. So, I figured why not just “spread out my primer” as the skim coat! It has worked GREAT, the painter jokingly says, “do you think I'll need to prime this or just paint it?” I tell him, “Just clear it, it's a shame to hide that work under primer”.
This method has worked great for me, it's more of a state of mind than a procedure.
And don't be afraid to buy the best sand paper and use a lot of it, the cost of the paper will be nothing next to the time and muscles saved. Find the paint store in town that services the PROS the Body shops in town, that is were you will get the right stuff and the right info.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#110775 02/12/2002 7:00 AM
Judd, I forgot to mention, those are "pin holes" you have and the "skim coat" I refer to in me "bondo" basics would eliminate it.
1948 Chevy Pickup
