3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Anyone have a belt number for a GMC 270 with 3/4 belt. Shredded my fan belt pretty good. Can barely read but think is a Gates 166, but nothing similar comes up on google. Search the forums but nothing for 3/4 inch belts. 1950 GMC 270 in 450 series fire truck. Thanks. Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a Rockauto.com cross-referenced part for the Gates 166:
GATES Part # TR28437 {#166, 19A1095, 20A1110, 20A1115, 2510950, 2511050, 2511100,2528437, 752} Truck & Bus V-Belt; VA 7/8" x 44-1/4" Category: Belt | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Replaced with locally sourced Gates TR28437. Fits great with Alternator having plenty of adjustment range. Little tight getting past fan and radiator. Bought at Hodges Heavy Duty Truck repair shop. In stock even. Also have backup to go under seat from RockAuto. Hodges about $27, RockAuto about $14. Thanks TC. Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for reporting back, Jim
This might help someone else in the future. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I just bought a new Gates fan belt for my 1946 2 ton yesterday. Green Stripe Truck and Bus Series TR20426 19/32" x 42".
The parts man said that the parts book shows there was two belts used. The belt for the heavy duty generator which is most likely the one fits. If not bring it back and he will give me the other belt. | | |
