4 members (walter74, Wayne67vert, 1955 1 Series, 1 invisible), 175 guests, and 4 robots.
Topics128,209
Posts1,057,462
Members48,471
I am starting to restore my 640 with a 471 and 5 and 3 trans. I am going to start by making sure the motor is okay and then I am going to replace the 5 speed with a 610 road ranger I have. Also does anyone know if they made a turbo 471? I will be in need of a few small parts like a factory air gauge or have mine restored. I will post pics when I get them.
Brad
Detroit did offer a 471 turbo version, but it will require different pistons and head. A turbo upped the hp by about 30.
Crusing in the Passing Lane
How are the Pistons different(compression ratio?) and head different?
I have a 630 with a 503 gasser and need a water pump and some other small parts, was thinking of putting a 4-71 in it.
Ed
Pistons and liners are usually different between turbo and natural Detroits. The compression ratio, sometimes port height, and probably where the rings are on the piston.
Head casting may or may not be the same, valve seat inserts are different, usually the valves, and sometimes springs too.
While you could just add a turbo to an N engine you'll have better long term results by starting with a real T engine, especially if you plan to work it hard.
•1952 Chevrolet 3800 pickup
---All pictures---
