0 members (), 170 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1104552 05/24/2015 5:33 PM
anyone know where to get a gas tank that fits between the rails of my 46 1/2 ?
ton? without too many alterations
The 55-59 Panel and Suburban's had their tank between the drive shaft and the frame. They are straped between two of the crossmembers. I'm not sure it they did it that way in '46...
Have you checked out Tanks Inc.?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
My 47 3/4 ton had the gas tank mounted to the frame on the passenger side. I bought a tank that I had intended to mount on my 54 1/2 ton but it was a little too large. you'll have to find one that isn't very tall or it will hang down too far. the 1/2 ton doesn't have a lot of clearance.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
I have a brand new one . well not quite, never used purchased new been in the garage for about 2 years now.ill have to check my reciept but i think it came from classic chevy truck parts!!
Hoozat,
What are you really looking for? Something that's from another truck that fits or custom?
Gas tank
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Be darned if I can remember what it come out of but there are tanks that will fit between the frame and drive shaft. Built a 46 around 25 years ago and it has a junk yard tank in it. Had to make mounting brackets and move filler but was not a hard job. Filler on drivers side and holds 16-18 gallons IIRC.
http://s32.photobucket.com/user/coilover/media/Trigger%20005.jpg.html
Evan
looking to put a tank between the frame rails in back of my 46 1/2ton with the cap thru the bed floor
back yard wrench turner
I used a Mustang tank on my 38, click
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Moderated
Moderated
A 1990 S-10 blazer gas tank fits perfectly above and behind the rear axle. It comes in several fuel capacities with an available intake fuel pump sending unit. I used a 13 gallon tank in my 46 Chevy truck. A couple of small brackets and straps is all you need to install it. Fill is through the bed.
