9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | I have been using the vin and title as the 1948 truck is a FR model so therefore a 3600. But it has been on the back of my head since I bought it that it has a really long bed. In hunting radial bearings for the trucks front spindles, one site listed by wheel base and stake bed pockets. SO in double checking I know the bed has four stake pockets and tape shows 137 inch wheel base. But I am not seeing a FR model in 137WB in my books. Am I missing the vin decodes that show a FR 3600 with 137
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The cab, and therefore it's serial number and title, are probably not original to the chassis. The chassis is a 3800, which is 137" wheelbase. What's the engine number?
Bill Burmeister | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | looks to be a 216. shows on the flat stamped area AFGA 607438 The forward block (in front of fuel pump) cast GM2 3835849
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Were the early frames stamped for ID/MODEL numbers. If so where.
I don't mind the 3800 frame as long as I get the right spindle parts, king pins, wheel bearings inner and outer.
I have the old numbers on the bearings but trying to find source for roller bearing upgrades which is what started my line of what is in the box.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can't find a listing for AFGA, but there is a listing for AFCA, which was used on both 3600 and 3800 models.
Bill Burmeister | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Snap looks like a G has a bar across the lower half of it. I will get a fine wire brush out later and see if it is some thing other then a stamp line. But I guess even if a "C" not much help in knowing why the mix up. The swap if it was done happened a very long time back as the truck was setting many years before being sold at auction.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3835849 is a 1952/53 216 block AFGA? (engine serial number) AKCA? (is that a possibility for your code?) - 1952 3600/3800 AK was used as the 1952 year preface (truck) L was used as the 1953 year preface (truck) | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | 5FR. 5 (built in Kansas City, MO), F (1948) and R (3600). I think we all know that.
Perhaps there was a screw-up in Kansas City. Can't argue with wheel base. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Years ago that truck could of been in a bad accident and they pieced two trucks together to make one. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Always the case on any old car or truck, but still most confused on the vin tag showing 8800GVW.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Always the case on any old car or truck, but still most confused on the vin tag showing 8800GVW. You may or may not want to dig any deeper. Smells like a dirty title to me. Easy to put any ID plate on any truck one wants to as long as there is a title matching the plate. It happens all the time. Carl
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Especially with clutch headed screws that are all wallered out! steve sr. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Not worried on title it is cleared and check and matches the truck 100% from last registered in 60's. Based on history if a swap occurred it happened in 40/50s but was titled to show that effort if done.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | I was just advising about a potential for a dirty deal. I personally wouldn't worry about anything if it were my truck. Just as you cannot get to the bottom of it, no one else will be able to either. Carl
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | All the following is from my 1948 Chevrolet Truck Restoration Guide.
The GVW of 8800 on the VIN plate and the wheelbase of 137" both say 1-ton, of course. That truck (GVW 8800) had the highest GVW of any of the 1-tons and came with 7.00-18 tires. Those tires were needed to specify it as GVW 8800. What rims do you have?
Does the box look original? The GVW 8800's were sold as stake trucks among other configurations w/o a box.
Anyway, a guy grabbing an "R" stamp instead of an "S" for 1-ton would explain a lot.
