2 members (walter74, 1 invisible),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | Does anyone have a PPG paint code for ocean green. I have tried several that I found online with no luck. Thank you. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 |
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dennis (and 55mater), Mr. Google's code (PPG 41375) is also listed in the Stovebolt Tech Tip: Also, the tech tip gives information on a newer "offset" code: PPG 44621 | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks for pointing that out Tim. I'm searching for a green so was looking for this one. Forgot some were already on this site! I should take a stroll around here and refresh my feeble memory.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | Thanks for the info. I have already given my local ppg store the 41375 number and they said it did not pull up anything. Let me try the newer number you provided. | | |
