6 members (kades51, frogfarmer, baldeagle, Brian Moore, Hotrod Lincoln, 1 invisible), 28 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,419
#110608 01/24/2004 7:59 PM
Just wondering if anyone has used this poduct before and knows if it is good or knows of a better product. Was planning on using it and then priming with epoxy primer
#110609 01/25/2004 1:50 AM
Stuart,
I used Rust Mort when I restored my 63 Impala. It worked just great at neutralizing the rust to a black mass which I finished primed and painted over. That was 12 years ago and the rust hasn't reappeared. A word of caution - wear rubber gloves and don't spill it on any painted surfaces or contrete floor, because it will etch and stain it. (personal experience)
Recently, I purchased Neutra Rust from Canadian Tire and thought the results were every bit as good. It was a lot cheaper too. I got my Rust Mort from an autobody supply shop.
#110610 01/25/2004 3:12 AM
Frets
Thanks for the reply. I had a friend give me some rust mort So I will give it a try
