5 members (Gdads51, TUTS 59, MickeyP, tclederman, 1 invisible), 75 guests, and 1 robot.
Topics128,049
Posts1,055,695
#1102872 05/15/2015 4:35 PM
on my 59 Apache 6 cyl. with a 12V Gen. Had some charging problems.. Now I am getting about 14V across the battery. Someone said if system working correctly, I should be able to unhook the battery cable and the truck will stay running. Mine dies...
Is this true ???
Thanks to everyone who has helped
That is terrible advice, given by someone who has a limited understanding of the battery's function in the charging system. The battery acts as somewhat of a "shock absorber" in the system, leveling out voltage spikes as they happen, and also determining charging voltage to some extent. I have seen voltage spikes of 100 Volts or more on an oscilloscope when a battery cable is disconnected with the engine running. If you've got a radio with solid state electronics, or an alternator with rectifier diodes, goodbye electronics! The voltage produced by the charging system will only rise high enough to force a charge into the battery- - - -the "voltage regulator" function only establishes the highest voltage the generator produces when opposed by a fully-charged battery.
Against a low battery, or immediately after starting, the voltage might only be 12.5-13 volts, because that's all that's required to make current flow into the battery. As the battery recovers its charge, the voltage will rise, and the regulator should limit it to 14.5-14.7 volts if the battery is fully charged. Use a hydrometer to check the concentration of the battery acid- - - -that's the ONLY way to determine if its getting a full charge. Full-charge specific gravity should be about 1.265-1.300, while a completely discharged battery will have a S.G. of 1.000-1.100 or so. BTW, a badly discharged battery can freeze solid in cold weather, so never leave a poorly charged or discharged battery exposed to freezing temperatures!
Like Hotrod Lincoln said the battery is there to smooth out the voltage from the regulator and provide steady power to the ignition system. Very rare it will stay running and poorly at best without the battery...and only at more than a idle if it does. If it drops to an idle it will die. The voltage coming from the regulator isn't clean enough to run the igniton system.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
