| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I should finish polishing my 68 fleetside tailgate tonight. Those indented panels are a royal p.i.t.a.
Last night I had another brilliant? thought. What can be done to the inside of the gate to keep it frome rusting? It has the black primer that was dipped.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | Hey fred the best way i found to keep tailgates from rusting is to drill some 3/8 (i believe) holes in the sides of the tailgate. The parts where the tailgate is "boxed in" (my 62 only needed 1 hole on each side yours may need 2 on each side 1 at near top and one near the bottom)that's how tailgates rust from the inside out. And spray or even tip tailgate on it's side and pour some undercoating oil inside. Then get rubber plugs to put over holes. This will help keep the moisture from attacking the steel from the inside out. Plus you won't even harldy notice the plugs are there. And you won't see them for sure with the tailgate closed. *Note it is wise do to this AFTER you have painted the outside of the tailgate. Hope this all made sense  I mean what's better, 2 or 4 small rubber plugs that ya don't even really notice or a rusted tailgate? | | |
