| | | Forums66 Topics128,210 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | I need a new tank for the C60 and can only find one available for the 1/2 ton body. Will it fit? | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Yes, It will fit, unsure of the mounting tangs though. | | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | I can make the mounting tangs work as long as the filler neck is in the correct spot to fit the hole and the tank fits behind the seat. Thanks! | | |
