5 members (Phak1, Hanks custodian, walter74, Charles in CA, baldeagle), 164 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#110479 01/21/2004 6:59 PM
Hi all!
Was hoping that someone could provide me with their experiences of shooting House of Kolor paints over a PPG primer/sealer (K-36).
Shot the front end parts in K-36 this weekend and then Amy decided to change colors from a PPG to a HOK.
What is going to happen if I shoot HOK over PPG?
I have heard some horror stories, but there were too many variables to conclude that it was the primer that caused the problem.
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
#110480 01/21/2004 9:37 PM
I would ask HOK.
#110481 01/21/2004 11:18 PM
I have. ZERO help - all I get is a sales pitch. They won't even describe what MIGHT happen if I use it over ppg. Of course - they may not know.
Hopefully, someone has made the mistake (or not) and can tell me how it turned out for them.
I know that Tip Top primers and Clears work just fine under/over HOK. Which surprises me since HOK products are so sensitive.
- Ryan
59 Apache Step
78 El Camino
#110482 01/21/2004 11:46 PM
I would stick within one brand. Can't you have the color mixed in PPG?
54 3100 with 235
62 flatbed dump C60 with 261
#110483 01/22/2004 1:47 AM
in general I agree - but I'm NOT going to strip these parts back down to bare metal AGAIN. smile
I haven't been able to replicate that color - Tangelo Pearl Base Coat (HOK code = PBC-32).
That does not mean that another orange that is pearl will not work - just haven't checked with the boss.
Update: according to several places. Everything SHOULD work fine as long as I seal the primer (required step anyway). They suggested using a HOK sealer over the K-36 rather than adding a catalyst and reducer to the K-36 to create a sealer (see p-196p info sheet from PPG for details on using k-36 to seal).
- ryan
59 Apache Step
78 El Camino
