3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
#1100871 05/04/2015 10:19 PM
Gas Pumper
Gas Pumper
I spent the weekend designing a door addon for the SuperJig. This allows you to go from sandblasting to sanding and final topcoats with one jig. When you need to get to the hinge screw area, just take the screws out temporarily without moving anything. The door addon is near the bottom of the article here:
http://devestechnet.com/Home/SuperJigPlans
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #1101425 05/07/2015 11:44 PM
Gas Pumper
Gas Pumper
Turns out I have no complaints about this setup in longboarding and sanding every square inch of the two doors by hand. Every square inch of the entire truck gets sanded three times using three different grits, so I really appreciate when something doesn't move while pushing and pulling hand sanders across the parts. With the doors out of the way, the next setup that needs to be engineered will be for the fenders.
This SuperJig is awesome, but not for a guy doing a frame up restoration of ONE truck. Its mostly for people thinking they will do a few more. It took me a few days to engineer the door setup and it takes about 4 days per grit to sand both doors. It will be a real time saver on the next set of doors for sure.
Deve
The Think Tank
Deve #1101906 05/10/2015 6:13 PM
Pretty slick solution Deve.
Allen
1974 Stingray Corvette
Deve #1103002 05/16/2015 3:39 AM
Amazing Deve!
Chuck
A few Harleys and '76 Triumph Bonneville
Deve #1104599 05/24/2015 11:11 PM
I recently got a chance to see the Super Jig and it is jaw dropping awesome!!!
Deve #1104770 05/25/2015 9:37 PM
Gas Pumper
Gas Pumper
Wish you could have stayed longer. It was lot of fun!
Deve
The Think Tank
Deve #1122792 09/06/2015 7:26 AM
Very nice. I work harder fighting the panel as doing the work. Must Have
Travis
1929 1.5 ton
15' durango R/T AWD
more of my pics,family,work,etc
Moderated by  MNSmith
