| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | Hi all I am not a paint or body expert, which is why I am asking this question. I found a paint gun at a garage sale for a couple bucks and bought it. It is electric powered. It appears to have a small disk inside it that spins really fast and when you squeeze the trigger, a little door on the front opens exposing the disk, so it can fling paint out the front of the gun with centrifugul force. Has anybody ever used one like this? Are they good for anything other than a conversation piece? I haven't had time to play with it yet. Thanks
The shortest distance between two points is probably under construction
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I think those work pretty good to paint your garage door, but not the truck.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Well it might be better then painting your truck with a brush but that is yet to be seen now isn't it?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Don't use it to paint your truck. It will put waaaaay more paint than you will want on the truck. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Let me put it this way. Electric motors produce heat and sparks. Automotive paint is FLAMABLE  The two should not meet. If you want a cheap gun, go down to your Harbor Freight store and get a SATA copy for about $40.00. They can't be beat for the price.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | That's pretty much what I thought.....
