6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
My middle RB bracket is bent backwards slightly and the forward most upper rivit is pulled through the bracket. I need advice on how to bend it back into shape. Sledge? On frame or off? Heat will help, right?
Thanks!
You really need to put some pressure on it and then heat the area around the rivit so it will reshape. If you have access to a "friction jack" or a Porta-power that would be helpfull. But if you don't, you can use an old bumper jack. Position the jack against the base of the rear rb bracket. Then at the other end find a way to attach it to the outer most of the bent one. You can put a bolt through the bracket and jack up against it. Or you could bolt a small chain to it that is looped back to the bolt. Put the other end of the jack into the loop. Jack it out to apply pressure and heat the bent part at the rivit. You will probably need to "help" it with some hammer work but it will go. Then weld the rivit to the bracket around the hole.
If you are doing a resto that you want nicer than that, drill out the rivit first. Then after you have the bracket hammered nice and flat on the frame, re-rivit it.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
My driver side front bracket is broken below the top rivet. This allows it and the running board to flex up and down. And it all sits too low.
I bought a new bracket from Mothertrucker and will drill out the rivets. Then replace them with carriage bolts which will look almost the same.
54 3100 with 235
62 flatbed dump C60 with 261
Thanks guys. I will try Martinsr's idea first, but we'll see how it comes out!
