1 members (Jon G),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Gents,
I've reviewed prior posts on this topic, and can't quite find a post that deals with this directly.
I removed the manifold assembly from my '47 216 and finally was able to free up the exhaust gas deflector. (I used carb cleaner, PB blaster, and tapped it for and aft with a small ball peen hammer - no heat.) Once this was done, the spring was "slack" or resting about 45 degrees ccw from the pin. I completed the wind (tightened it an additional 315 degrees ccw) and set it on the pin.
The deflector has a positive bias to the "closed" (heating the intake) position, but now moves freely.
My question is, is this wound too tight? Where should the spring "rest" once it's been unpinned?
Thanks in advance for the help.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Sounds like someone put it on 180 degrees out of position.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes it's to tight. It should just hold the butterfly closed long enough for the bi-metal spring to relax and allow it to open to the exhaust pipe. By the time this happens the floor of the intake should be warm enough to vaporize the fuel droplets. I think Carl has it right, the thermostat was installed 180° out of phase.
dg
Denny G Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I know I saw a better example in one of the Old Car Manual project but Here is the page from the 42 book. Same thing more or less for reference sake.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Helpful as usual!
Thanks guys!
